Need Hood Hinge Assembly
SYNFULL
Bucks Co, Pa
Mine has "jumped" over the stop and I can't reload the spring without it jumping over the stop again. Now there isn't enought tension to keep the hood up.
I really only need the drivers side but will buy a complete set if I have to.
This is the part that bolts to the frame rail with 3 bolts, has the large wound spring, then bolts to the hood.
I contacted Paul Scharf, and others, but no luck yet.
Gary
bloose
Brighton, MI USA
You might try X2 Builders if you can't find them anywhere else. They seem to be parting out quite a few compatible donor cars. I've never bought from them and I can't vouch for them but I may buy a center arm rest from them soon.
X2 Builders
SYNFULL
Bucks Co, Pa
Thanks Guys, I got a price from Scott at X2 and will check with Jon. BTW I bought a lot of things from X2. They seem pretty reliable.
Gary
Puntacanaviper
