Need paint code for black 94
SNAKE BITE
Belvidere, Illinois
I want to make sure when I get my front fascia re-painted that I get the right paint. Can someone give me the paint code? Also does there need to be a flex agent added to the paint or clear?
SNAKE BITE
Belvidere, Illinois
After researching i've found this info but don't know if it is for 1994 year Black RT/10?
Sales Code: PX3
Chrysler: MX3
PPG: 9874
DuPONT: F0840
Sherwin Williams/Martin Senour: 46951
Akzo Nobel/Sikkens: CHA93:MX3
Spies Hecker: 70268
ICI (Autocolor): 2PA1B
Also is the Akzo Nobel/Sikkens: CHA93:MX3 the paint the factory used?
What if any additives/flex agents need to be added to the paint or clear for use on the front fascia?
Thanks!
8AV8
Towanda PA.
http://www.paintscratch.com/
I used these guys for touch up paint on my black 94 rt/10 it matched perfectly.
Viper Black Clearcoat X3/MX3.
"If you are painting a flexible surface (such as a rubberized bumper) and you are spraying the paint, you should order the Bulldog Adhesion Promoter as this is required for proper adherence for the primer, basecoat and clearcoat. The adhesion promoter is only required when you are spraying the paint and not for the touch up bottles and paint pens."
This is a good site that should be able to answer all your questions.
C-Note
Near the Edge
Guys, black is black so long is there is not metalic in it any black base clear system will work.
C-Note
Near the Edge
He is wrong, ther is only one true black. If it a tid bit lighter than black it is actually a grey. I have four black cars and have done alot of body work in my life, trust me on this one. :2tu:
controlf5
