Need solution - Moving Viper around in small garage
Kmrumedy
Montreal, Canada
I am storing my car this weekend. I rent a secured garage. The garage is only 12 feet wide (20ft long) and the 8ft garage door is not centered but rather on the far right. So when I park the car the passenger side is only about 1ft away from the far wall.
I want to do some winter projects and I need to be able to move the car horizontally when I want to work on the passenger side.
I saw this product on ebay but they are only good for tires up to 9inches wide.
eBay Motors: Hydraulic Vehicle Positioning Dolly Car Wheel Lift Jack (item 250188720998 end time Nov-19-07 10:01:48 PST)
Thoughts? Would this work? Would these work on 10 and 13 inch tires?
Anybody have any other solutions? I am open to ideas.
Scratch
Phoenix
Since you are storing it...couldn't you place some narrow (spare) tires on it, would that work for what you are going to do :dunno:
RAYSIR
Salem, OR
I made some steel plate dolleys. 1/4" steel about 12"X18" caters all 4 from a True Value. Tack welded 1" angle across so tires couldn't roll off. I've even used them with jack stands on them. 'Go Jacks" makes an expensive set. I only had about 40 bucks in mine for casters.
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
If you have room to jack up your Viper, you could use some wheel dollys from Harbor Freight. I think I paid about $40 per pair and they will accomodate Viper tires. The Viper is pretty easy to roll on these.
K
Kmrumedy
Montreal, Canada
Great suggestions guys. Thank you. I found the vehicle dollies (harbour Freight) for $80 for a set of 4.
Thanks a bunch!!
kc651
