New member... My Viper Pictures..Enjoy
HI-NOS-Viper
Hawaii
Twin 76mm Turbos, WOW. That is some serious power. Put some slicks on that bad boy and take it to the track and run some 7's. If you could keep the tires from spinning that is, thats a huge problem at that point LOL, I know stating the obvious. Nice car, nice build, once again UGR has built a very impressive Viper.
K
K-80-123
Oklahoma
Walt , You win the 06 Viper , best of everything..........
Roof has one almost just like it for sale that ran a 9.8 on street tires, with a similar build , correct me if I'm wrong.
Hi Josh, yep your correct....I hope someone finds that car a new home I have ridden in it (roofs car) and it is really nice and brutal fast.
Thanks again for all the comments about the car.....I have put about 600 miles on it since completion.....puts a smile on my face each time I drive her.
SnakeBitten
Very nice.....Love the HRE rims..looks exactly like my Iforged Senekas except these dont have rivits.......Hit the track and be safe...Cant wait to see the numbers this beast puts down...
Vipermann
Texas
The details:
Custom 530 Stroker
Full blue print race short block
Oliver Billet rods
Custom Billet stroker crankshaft
CP reverse dish race pistons
CP oil rail support
CP spiral locks
CP 180+ wall wrist pins
Clevite coated race main bearings
Clevite SBC coated race rod bearings
Total seal TNT file fit rings
Program Billet main caps
ARP Studs
Custom CNC JM Stryker heads
1,200 degree spark plug wires and heat shields
Crower shaft-mount roller rockers
Hardened push-rods
Billet in tank fuel system with quiet option
95 lbs injectors
Custom twin 78mm turbocharges
2 tial 44mm billet wastegates
2 tial 50mm billet blow off valves
Stainless steel mandrel bent high flow exhaust heat coated
Custom Heat shielding
High pressure t-bolt clamps for intake pressure
Custom UGR camshaft
Custom intake with show polish
Custom single blade throttle body
Electronic Boost controller
Alan's custom Performance radiator
AEM 10 channel injector driver
Custom wiring harness
Aeromotive adjustable fuel pressure regulator
Custom show polish fuel rails
Custom Methanol/water injection to inlet pipes
G-force upgrade
Custom upgrade 5 & 6 gear
Triple cone transmission upgrade
Custom Billet flywheel
Custom Twin disk clutch
Street Twin
Melba lining
Three finger pressure plate
Quafie differential
Gen-2 Mark Williams billet CV half shafts
Custom Penske coil over suspension fully adjustable
Custom suspension canister mounts
Custom HRE Wheels
Nitto Invo tires
Alpine DVD custom stereo system
XM Radio with hidden antenna
Back up camera
AEM stand alone computer
All that, but no ZR1-style see-through hood?
:D
Burntrubber
Phoenix
I still think you should bring it to the AZ GTG:D:drive:
Get us some vids, I don't want to read about how "hard"it pulls in 5th, I want video's:2tu:
ViperGear
