After getting ONE issue of burnt boots on a customer's car from our wire sets, we are going to be offering this option for the wires. It's a 1200 degree boot cover. It will slide over the spark plug boot and protect the boot from heat. Now this is not a necessary option you need to take. The last person who had the issue with the burnt boots did not have the factory installed metal heat shield sleeves installed in his car. They were missing. So any spark plug wire boots would of had some issues. I know there are vipers out there that maybe missing this item on their car so my solution for this add on is this.
Cost to add this sock on is $10.00
Now compare to other socks out there for boots would cost over $50.00 or more and not sure if they would fit in a Viper. Mine will fit and will do the job if you are missing your OEM heat shields.
Just wanting to make sure I respond to issues that arise even if it's not the fault of my wires.
www.qualitywires.com We are the only ones that have different colors for your wires that you can pick! Plus we have the protection of hi temps!
