New viper owner with question on top/windows
BADVENOM
port washington, n.y. usa
Just purchased a 96 rt/10 with 10,000 miles. Black/silver stripe/black interior. I,m getting delivery with inside carrirer on sunday and I,m starting to ge the itch.My question is the car comes with factory hard top and I have been told that it a pain in the !!! you know what to take off and on. Abyway I want windows for the car. Will after any after market window work with my top or any aftermarket top?
Viper Wizard
South Salem, NY USA
Adam, CONGRATS and WELCOME!
The top is not to bad with two people. Remember you bought a "Roadster"! Go *******!!
Viper Wizard
South Salem, NY USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by adam96:
Thanks viper wizard but what do you think about having windows as an accessory?
By the way Live long and proper!
<HR></BLOCKQUOTE>
If you kept it above 40mph, you'll never get wet!
SoH buS tlhIngan?
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Viper Wizard on 12-20-2002 at 06:44 PM</font>
Jeff Torrey
Plaistow, NH USA
Adam- The 96 Windows are actually a lot better than most of your window options. Big slider (largest opening)they work great for toll booths. If you want "Hard Windows" Vipermania can help you with this. Good luck with the car.
ruckdr
Renton, WA USA
Adam,
Congratulations on your Viper, you will have fun.
The factory hard top is a SNAP to put on and take off. Since you car is coming with the top on, all you need to do to remove it is unscrew the 2 allen head bolts from the inside that attach the top to the front of the sport bar; unlatch the two catches above the windshield by rotating, then lift the top off. You should get 4 bolts and the leather forward part of the sport bar to put on when the top is off. Screw the 4 bolts into the sport bar in the appropriate places (only place they will go), turn the bolts in most of the way until the bar will slide down over the protruding bolts (the bar should have slotted holes). Tighten with a 1/2 inch open end wrench from the slots under the bar. To put the top back on , reverse the process.
I actually have put my top on by myself, by opening the door, grabbing the front and back of the top, and step with one foot into the seat (carefully, no shoes), and let it down into position.
One of the first things you might consider is adding door pops (electronic door openers) to your ride. Send me an email if you are interested, also check the "How TO", "Illustrated Upgrades", "Door Solenoids" section on the forum.
Have fun, and enjoy!!
Later,
GCHDEALER
MARIANNA,FL,USA
Trash that factory stuff and go with Vipermania. The windows look great and the top is more aggressive than the factory top. The top and window system is top quality and can be removed and put on by yourself. Also you do not have to remove the sports pad on your car with is a pain in the @ss. Call Biff Brown!!! Here is the link www.vipermania.com
bmillionaire
