Well, I just installed a new exhaust on my 99 ACR. I picked up the headers from 1Tony1 (thanks Tony) and got the rest from a member here on the board.
The 02 sensor wires on the pass side melted somehow after the install (heat from merge collector??), causing the PCM fuse to blow and the car wouldn't start- would crank but not turn over. Took awhile to find the problem but now all is good!
The sound ended up sounding stock at idle, just an amplified version. Under WOT it sounds pretty good, but it has zero deceleration popping.
Here is what I put on:
B&B 1 3/4 headers
Random Tech High Flows
Borla Catback (the ones with the inner tips)
What to do? The system on my old ACR was a full belanger, and it sounded awesome. This just isn't loud enough and doesn't have lumpy, burbling sound I was looking for. More of a consistent, deep roar.
Should I just replace the catback or cut the cats off?
B&B 1 3/4 headers
