I Bin Therbefor
- Joined
- Jan 12, 2012
- Posts
- 387
- Reaction score
- 0
IMHO, once we get the Viper well and truly launched. Here's what I'd like to see:
A radically improved dealer network adding value to the ownership experience. On second thought, I'd like to see this right now.
DI. I know the problems with applying it to a two valve push rod engine BUT it can be done.
A trans similar to the Audi S Tronic. For those not familiar with this design, here's Audi's explanation. “The new 7-speed S tronic, with a three-shaft layout, is less than 23.62 inches in length. Two multi-plate clutches lying behind one another, serve two mutually independent sub-transmissions; gears are shifted directly as the clutches alternately open and close. Gearshifting occurs practically without interruption of tractive power within hundredths of a second, and so dynamically, smoothly and comfortably as to be hardly noticeable.” "In translation what this means is that when you gun this car, there is no loss of power during upshifts."
