I have used the bottle on cars in the past (10yrs ago) and my last car I used something call Jacobs Mastermind. I have seen other controller systems and they seem to be way more advanced to the point my head spins. Im wondering what your using and how easy to use is it? Id love to have some type of touch screen to replace the sub par radio.
My plans are to plumb a direct injection system with HPA pushing two bottles. What I am hoping for is RPM window switches, TPS switch, RPM cut off, pressure cut offs for the fuel & bottle and I need a little insight on the A/F and what these different system can do with that info.
1. What do you have and how easy is it to use?
2. If you had to do again would you be using the same controller?
3. Do they have a system that takes your bad a/f or exhaust temp reading and warns you along with disarming the system?
Pre thanks!
Pre thanks!
