Torquemonster
Russ M's reply is a very good one.
On carby engines the old Jacobs Nitrous Mastermind or something similar provided a basic EMS for nitrous. It regulated the flow according to engine demands and rpm, adjusting timing & mixture according to the presence and flow rate of the nitrous.... this makes high nitrous shots much safer and engine life considerably longer... Guys who ran just the NOS kits usually ended in tears at some point.
but for EFI - I would assume that nitrous kits fitted to Vipers come with a way of controlling flows at low rpm and increasing NOS as rpm and load increases, I'd also assume that some kind of EMS enhancement would compensate for nitrous via a retard timing map and fuel enrichening mixture map for when Nitrous is on... with knock sensor providing back up protection via additional retard as required... am I correct? If not, I'd leave bolt on NOS for the brave, and spend more money for a profesionally built setup that can be controlled precisely.
