Not sure if CF kit is going to fit........any help?
yellow02
NY
Im just received my cf kit from TNT, and i am questioning weather or not the peice over the tach/speedo is going to fit right. when i lay it over the top (with 3m on back still) it looks as if it will not reach the upper left hand gague. I can stretch it out kindof, but it still does not look quite like it will fit. As you can see my car is a 02 and the kit came with door handle covers for earlier gen 2s. Im questioning weather or not all of the 2nd gen interiors are the same.... or maybe it will end up fitting when i acutally apply it. maybe im being stupid... just wondering if anyone else may have had a similar problem? thanks a lot anyhow
Vip-RT10
Clearwater,FL.USA
I don't have that kit, but in general, what you dois heat up the piece with a hair dryer until it gets moveable to test fit it. Try that to see.
Y
yellow02
NY
when i use the hair dryer it gets nice and flexable but i think the 3m tape on the back is restricting it from actually changing shape perminately
FirecatF7
