Snakebitten:
Not at all - optimum a/f on a N2O car is first achieved with proper jetting. Jets are fixed entities and their results are repeatable every time. Why add the VEC1, in affect you are than using two devices to achieve the same end. In addition, the VEC1 has a learning curve, from my experience on the dyno with the VEC1, what you see on a dyno immediately after a change in the VEC's settings, is not what you will see tomorrow. That is OK on a NA car, maybe not the best on a N2O car.
What happens when you run NA, do you change the VEC settings. What happens if you forget in the heat of battle to change it back. Also throw in the fact that the settings don't change instantaneously. The whole VEC scenario on N2O is to ify. Once you get your jets set right nothing else should be needed, isn't that far simpler.
If my car had mods and no N2O, I wouldn't be without the VEC.
NEXUS-6:
Good point, maybe Tom or Sean will chime in. Tom already had a post about two years ago where he talked about the difficulties of using the VEC1 to tune a N2O car.
