dave6666
On advice of my soon to be SCT flash tuner - Dan at Viper Specialty - I moved my O2 sensors from the single down tube on my Belangers, to the merge collector. I had previously solved a preheat code while still on the single down tube by drilling the sensors out. Now the codes are back again.
Guess I need some of them quick fires huh?
Anyway, feel free to admire my wiring job. A week of evenings basically. It looked like the only way to ensure routing away from the hot items was down the center frame rails. I drilled the large hole for the grommet - big enough to pass wire connector through - and then covered it all in plastic loom and then heat shield. Soldered and heat shrink on the wire joints of course.
I read in some posts that people were able to make the wires stretch and reach. Umm. OK.
