O2 sims on a '99?
Silver Snake
San Diego, CA
Re: O2 sims on a \'99?
DO NOT, :confused: DO NOT remove cats in Kali :2tu: Don't forget smog :eek:
Mark you should no better :usa: :D :cool:
Dave, I would never.....I mean come on what kind of.....I am....
It's for testing...Yeah, that's it! Testing.
Yes, the sims work on 99's.
Ulysses, I don't doubt that they will "work" on a 99, I am wondering if I even need them on a 99. I thought Vipers that are older the XXXX did not need sims and I am just wondering if the 99 is in that group.
Mark
Ulysses
San Diego, CA. USA
Ohhhh!!! So why didn't you say so............... or did you? LOL!
The 99's will require sims but as you can see, as 99 R/T 10 proves, every once in a while there is the exception.
But since you are OE, Mark, I think you are going to need them. You can always run w/o the sims and see if the CE light will come on and order the sims later. I'm sure Roe or whom ever you get them from can overnight them and if your not using the Viper as a daily driver it shouldn't be a concern.
Silver Snake
San Diego, CA
Could I just unplug my O2 sensors now and then wait a while to see if it sets a code?
If so, how long would it take for the "Check Engine" light to come on?
Mark
99 R/T 10
Enterprise, AL USA
If you just unplug them, the check engine light will come on right away. They need to send some kind of signal to the PCM.
PhilC
Jackson, NJ, USA
I have a question which is related to this topic. I hope you dont mind my temporary hijack.
I have a 99 acr no cats. I do not get a check engine but DMV gets a not ready when trying to inspect . the not ready is in only two categories (both of which are related to the o2 sensors I believe.)
My question is, will o2 simms deal with this or is my problem somehting altogether different. (btw I have thousands of miles on it since last battery disconnect so I dont think its a learning issue)
Thanks in advance
Phil
Silver Snake
San Diego, CA
Duh! :smirk: That makes sense. Thanks.
I don't have the sims and am w/o cats. No problems so far(been over a year).
It's beginning to look like I am not gonna need sims. :headbang:
Mark
mntngts99
Boise, ID, USA
Silver Snake
I just pulled my R/T cats off today, no Sims and Went for a one hour drive and no codes.
SYNFULL
Bucks Co, Pa
Silver Snake
How does it sound? Do you have headers?
gary
DrumrBoy
GA
Scotty just wrote me and said they should be there....it was just today so perhaps tomorrow or Sat!
Puntacanaviper
