GTS-R 001
Dodge Viper SRT10 front mount TWIN TURBO SYSTEM by our new Performance Upgrade division
ABSOLUTE PSI (Absolute Power and Speed Industries)
This system has been designed to work on both built engine (forged rods and pistons) and stock engine SRT10 Vipers.
This system will work on both VIPER SRT10 Convertibles and Coupes.
We use only the best components, TiAL Blow Offs and TiAL Waste Gates, Comp Turbo Billet oil less Turbos, no more oil problems that plague other builds, no turbo timers required as our turbos are WATER COOLED and do not require oil lines, they run coolant through them just like your engine does to stay cool! Our turbos cost more than most other people's complete turbo systems! The Turbos themselves are the heart of a turbo system so we do not scrimp.
Our Turbos Spool up SUPER FAST and create TORQUE ON TAP™, you will not feel lag with this system, look at our torque curves (if you can call them that) on our dyno sheets, they are flat, and this is on a DynoJet Dyno, on the street you will feel the torque about 1000 RPM sooner. Our systems can easily be installed and our first 5 systems offered in this promotion are offered with free installation.
Includes:
System makes ~775 RWHP at 8.9 PSI
System is 1000 - 1200 RWHP capable with a built motor!
$11,995.00
First 5 systems come with Free Installs,
Call with questions, 707 849 0111
Optional Built Forged motor versions with standalone ECU's available for an extra cost, system is capable of producing 1200+ RWHP with this option
We also have Gen 2 Viper Twin Turbo systems and REAR MOUNT Twin Turbo Systems
We have optional Turbo headers and Optional vertical flow Air to Air Intercoolers!
Pictures
The regular system
The upgraded intercooler system
Includes:
- 2 x Triple Ceramic Ball Bearing Comp Turbo Turbos, 6265's or 6765's, Oil-less, Billet Wheel, Water Cooled Turbos (see Comp turbo website for more info - http://www.compturbo.com/ )
- Fuel system upgrade, either Boost a Pump or dual extra fuel pump system (as in pic)
- New 2 bar MAP sensor
- 10 Reflowed (to our spec) Fuel injectors
- 10 NGK (colder) spark plugs
- Custom Air to Air, front mount inter-cooler
- Custom Turbo Intake
- 2 TiAL Q Blow off Valves
- 2 TiAL MVS Wastegates with multiple waste gate springs,
- 2 Air filters
- Custom Turbo to Inter-cooler piping
- Custom Inter-cooler to Turbo intake piping
- Custom header to Turbo hot-side piping
- All required silicone connectors and T-bolt clamps
- SCT tuner with 3 Custom TURBO Tunes
- Vaccum lines
- Water coolant lines
- Turnout to hook up to 3" cat back exhaust
- Uses stock exhaust manifolds
$11,995.00
Pictures
The regular system
