swexlin
I had my oil cooler lines replaced last year, because there were leaking, common problem. Well, back when I had the car on a lift a couple months back, I noticed seepage from a line the is in front of the pan underneath, it is a hose in the center, with two O-rings on it. Oil is seeping slightly out of there. Enough to make a very slight spot under the car, actually the spot is from the blow-back onto the belly. I thought the lines were leaking again, but this seems different.
What is that line? This on on an 03.
Thanks,
Thanks,
