Invasivore
I see that the OEM oil pan gasket is quite a bit more even on VPOA's site. Anyone have experience with the fel-pro ones?
Fel-Pro is a highly respected, quality gasket manufacturer. I use a lot of their gaskets, but for the Viper, I would use the OEM gasket for sure.
The OEM Gen 3 intake manifold gaskets are Fel Pro so some of their stuff on our cars is OEM.
It appears to be leaking at the gasket so I was going to replace it, to answer your question
Howd the thread go this far without someone saying: "The year matters...."
What year is your motor Invasiv?
up until 97was a standard type gasket that was superseded halfwaythrough 97 with the 1/8" thick aluminum "shim" gasket.
The new gasket is pricey however used ones can be had from salvage yards for half the cost. I'd take a used one over a standard type aftermarket replacement. I think the thick aluminum allows for more evenly distributed torque to the pan and is less likelyto leak. http://www.viperpartsrack.com/ could prob have one to you in a few days. Give JonB a call.
Where is it leaking? I went down this same path a couple of years ago. I thought the pan gasket was leaking and replaced it even though there was nothing wrong with the old one. Then I found the real cause of the leak was the rear main seal plate gasket. It is a inverted u shape gasket on the back of the motor. There is plenty of threads about it and it is the most common cause of oil leaks for the Gen2. The second would be the timing cover gasket on the front of the motor.
Im going to double check exactly where it is leaking. Are those gaskets easy to change?
