The under carriage of my car is very clean. This past weekend I fired up the car in the garage and let it iddle for 15 minutes or so, and then shutt it off.
Next morning I see a spot of oil under the car right in the middle of the pan. After messing around with a mirror for a while, I pulled the jack and lifted it up.
I had a drop hanging right at the end of the oil pick up gallery in the middle of the oil pan. I traced the oil, and as far as I can see it looks like it is coming from the area where the oil pick up gallery mates with the block(bolts and gasket).
From the gasket towards the top of the motor it is dry. I do see the front bolts around the oil pick up with a tiny bit of "shine". It does not look wet in that area, but it has the shiny look on it.
Should I go ahead and buy the oil pan gasket?, or just replace the bolts with some sealant. I got to redo my turbo drains, so the oil pan will come out anyways, however I was planning on re-using the gasket.
I see some silicone around the gasket, is this common practice?
Car has not leaked until now, it is a brand new motor.
Thanks in advance for your opinions/suggestions.
JC
JC
