Oil Pressure and RPM
Gerald
Near Tampa Bay
While the oil pressure gauge is wonderful thing, what is the normal Oil Pressure range at IDLE? What is the normal Oil pressure at , lets say, 2500 RPM?
I see to hit about 20 psi at idle and a little above 40 when I drive. (Yes, my oil needs changed bad) Just curious, is this normal range?
Gerald
BigsViper
West Texas, USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Doug Supercharged Vipers:
....Best way to determine oil pressure: Install a mechanical gauge for a more accurate reading. Electrical gauges suffice for good informative reference, but don't reflect precise numerical readings, especially when diagnostic troubleshooting is imperative...<HR></BLOCKQUOTE>
So Doug, do you have a good recommendation for a mechanical gauge? Preferably one that maintains interior aesthetics, yet is functional as you describe? Thanks
99 R/T 10
Enterprise, AL USA
Hey Doug,
help me out here, I was told(high school shop class
) that as a general rule, we should hav 10PSI for every 1000 RPM. Is this about right or is it different for this particular engine? Now it has been, ......cough, 20 years since shop class.
Mike
Fort Lauderdale, Florida.
Hello Mike -
Way too many factors effect oil pressure readings:
In part, engine temperatures, manufacturer tolerances, 10w 30 vs. 5w 50, oil type, engine wear etc...
Question is: Which would you prefer? Higher oil pressure with a thicker weight oil -or- lower oil pressure with a thinner weight oil that moves oil across reciprocating parts more efficiently?
Have a great weekend!
Doug
