OK ZAINO IT IS, NOW WHAT
King GTS
Houston, Tx.
Z1, Z2, Z5, Z6, AND THEY HAVE SOMETHING NEW CALLED EFX I THINK, WHICH TAKES THE PLACE OF THE Z1.
USAF BAD ASP
Vetper bliss...
At first I thought zaino might be another hoax or something that doesn't really work. But since everyone on here used it I figure it must do something.. well, my first 8 coats went on in the garage and honestly I didn't see any difference.. then I took it out for my first drive. It was at night. as I walked out to my car from the store I could see a huge difference. It looked like it was wet. It's like the difference between washing your tires and letting them dry, or washing them and then putting on that gel which makes them shine and look wet. It was WELL worth the price and time.. Even my friends noticed a difference.. especially at night..
Todd Richmond
San Jose, CA
I was wary, but after using a dozen or so different waxes over 20 years, it is the best I have found. The only issue is time - if you aren't up to spending an entire day+, Zymol does a great job for much less $$$ and takes 1/4 the time.
Pros:
Great shine
Seems to hold it's slick clean feel for much longer
Reasonable swirl remover for certain colors
Cons:
1-2 day effort
Lots of static electricity
Here was my work. Use VERY little wax - it took 2-3oz z5 and 2oz Z2 to do BOTH my 97 GTS and 2002 Acura in 1 day - I was absolutely beat at the end of a long long day
1) Clay bar - mandatory for anything over a year old. Work in very small sections and use plenty of liquid - if the bar sticks at all, you need another spritz. You don't have to rub hard
2) 3 Coats z5 w/ ZFX. Wait about 1 hour between each coat. I did 1 very light coat of z6 before the last coat. All wax on/off should be done in back/forth motions, not circles
3) 2 coats z2 with ZFX and light coats of z6 before and in between.
4) Finish off w/ 1 medium coat of Z6
5) Collapse and swear of waxing for a couple of months.
Todd
MichaelP
Orlando FL and Seneca Lake NY
STEP ONE:
Make sure vehicle is clean. Apply a thin coat of Zaino Bros' Z-1 Polish Lok™ Pre-Cleaner and Gloss Conditioner in a circular motion, using a 100% cotton towel or applicator. No rubbing is necessary. Entire vehicle may be done at one time. Let haze, DO NOT REMOVE Polish Lok!
STEP TWO:
Apply Zaino Bros' Show Car Polish to a clean 100% cotton towel or applicator. We have found the best way of applying Show Car Polish is with our #314 Custom Polish applicator. Just slightly dampen the applicator with water or Z-6 "Gloss Enhancer" spray. Apply Show Car Polish directly to applicator. This technique will help increase flow and spreadability on the paint surface and yield more coats per bottle. Apply directly over hazed Polish Lok, let dry approximately 30 to 40 minutes or longer. Please use Show Car Polish on all wheels, metal, chrome, painted trim and plastic lenses. Remove with a clean 100% (Made in USA) Large Bath size White cotton towel, turning towel frequently until all polish is removed. A large towel is necessary to completely remove polish. You will see a "wet-looking" crystal-clear, ultra deep gloss. Note: It is not necessary to use Z-1 Polish Lok™ every time you polish your vehicle. Z-1 Polish Lok™ is recommended the first time you do your vehicle and thereafter, once a year for show cars and twice a year for everyday vehicles.
TRICKS:
Want people to envy the look of your vehicle. Want that Show Winning Edge and Custom Paint Look. Want the deepest, wettest, slickest, clearest, richest, and shiniest paint ever. Apply two more coats of Show Car Polish waiting at least 24 hours before applying the next coat. Show Car Polish will continue to get deeper and wetter with each succeeding coat, up to five coats. You can however, apply as many coats as you want of Show Car Polish. You will not believe the depth and optical clarity of the wet-looking gloss. Follow up with Z-6 "Gloss Enhancer" Spray between every coat of Show Car Polish and see how Incredible your vehicle looks!
Want an even higher level of optical light refraction and reflectivety. Here's how. When applying Show Car Polish do the following; On all Top surfaces of vehicle, use a back and forth motion (from front bumper towards windshield). On all Side surfaces (doors, fenders, etc.) use a vertical motion, up and down. This technique will increase the way light attracts and reflects off of Show Car Polish. The body lines and contours of your vehicle will seem to glow. This trick really works. Remember to use Z-6 "Gloss Enhancer" spray between every coat of Show Car Polish.
TIPS:
Zaino Bros' Z-5 is the first non-abrasive polish that will eliminate swirl marks, fine scratches and spidering, without hurting the integrity of the clear coat. It does this in stages, anywhere between 1 to 5 coats, depending on vehicle color. With each application of Z-5 polish, you will see the swirl marks and fine scratches gradually lessen, until the marks are no longer visible and your paint will look flawless. Z-5 can be used initially after Z-1 or at anytime thereafter. You should switch to Z-2 as soon as you are happy with the way the paint finish looks. Example, no more swirls, scratches etc. It's up to you. Z-2 has higher optical properties than Z-5. You can switch from Z-2 to Z-5 and then back to Z-2 as often as you want. All Show Car Polishes are 100% compatible. For the highest optical paint enhancement. You should always end up with Z-2 as the last coat of polish.
Zaino Bros' Z-6 Ultra Clean "Gloss Enhancer" Spray is the ultimate maintainence product. It will remove light dust and soil between washes and will make your paint slicker, wetter-looking, deeper and reinforce the polish system and UV protection. Because of its unique optical enhancers, Z-6 "Gloss Enhancer" spray will create a three dimensional, ultra-high, light refracting paint finish. Its super anti-static properties will reduce dust and dirt pickup by up to 60%. The more you use Z-6 "Gloss Enhancer" spray the slicker and more dust-free your paint will be.
NOTE: Z-6 is very concentrated. Use sparingly, very lightly mist a small 1' x 1' section at a time and immediately wipe with a 100% cotton towel, turning towel frequently, until completely slick and dry. Repeat until entire vehicle is done. Do not let Z-6 dry on car without wiping. If product drying occurs before wiping, reapply Z-6 to affected areas and repeat drying procedure. Less than one ounce will do an average size vehicle. Works great on rims, chrome, trim and plastic.
Zaino Bros' Z-7 Show Car Wash will clean heavy soil from your car and deposit a reinforcing layer of polish and UV protection. It will not leave a film or haze like other car washes. Its great for maintaining that Show Car look, all year round.
Zaino Bros' Z-10 "Leather in a Bottle"tm will maintain new leather and give old leather, the look, supple feel and smell of brand new leather. It contains the highest quality, leather oil concentrate available. Nothing on the market beats this product! Works great on vinyl interiors and dashboards.
Zaino Bros' Z-12 Clear-View Glass Polish is great for restoring old glass to like new, using a low speed machine with a cotton bonnet.
Zaino Bros' Z-16 Perfect Tire Gloss is a non-oily, non-greasy, rubber protectant and finishing treatment. It leaves an incredibly durable, water repellent, perfect looking satin finish, that's only slightly glossy and dry to the touch. Use on all exterior rubber, tires, moldings, plastic trim, weatherstripping, underhood hoses and more. Just wet a sponge with Z-16 and apply to the surface to be treated and let dry. It will last thru rain and multiple washings. Z-16 is not recommended for interior seats or vinyl tops.
Zaino Bros' recommends using only Large Bath size 100% Made in USA White Cotton towels with all of our products. Cotton T-shirts are too small for polish removal and not as absorbent or fluffy as towels and most contain polyester. We have found that certain towels; especially those manufactured abroad, although they say 100% cotton. They are not; they include a blend of polyester and nylon that will definitely scratch and leave swirl marks in your paint finish. The rule of thumb is to use high quality Brand Name large bath towels (Cannon or Fieldcrest) that say 100% cotton and made in the USA. Towels sold in bags in Auto Stores are not 100% cotton. Look carefully on the bag it will probably say made in Pakistan or Bangladesh or other foreign country. Do not use these towels. They will cause swirl marks and scratches on the paint surface. Always, remove the stitching around the towel prior to use. Bargain store polish applicators also contain polyester and nylon fibers and are not to be used. Also, when washing your towels, please do not use any type of fabric softeners. Always use White towels. Do not use Colored Towels they contain dyes.
j
j
j
Because Zaino Show Car Polish is optically perfect (99.9%) The optimum results are achieved by using over wax free paint.
2. If you are looking for the ultimate paint surface preparation. Use Zaino Z-18 ClayBar first or skip to Step 3.
Zaino Z-18 ClayBar was designed to remove airborne contaminants, paint overspray, water spots, rail dust, industrial fallout, diesel fuel & catalytic converter residue and any other bonded surface contaminants from paint. All cars even brand new factory paint has airborne contaminants... Here's the deal. The non-abrasive Z-18 ClayBar will remove any surface contaminants from the paint finish and not hurt the clear-coat. The ClayBar will get that paint finish smooth as glass. Now remember waterspots, bird droppings and bug guts if left on the paint finish for any length of time. Will etch into the paint finish. The ClayBar will also remove any store bought waxes....
I recommend you use my car wash (Z-7) as a lubricant for the ClayBar. Just make sure to keep the surface area lubricated while using the ClayBar. Use 1/2 capful of Z-7 Car Wash to 12 ounces of water. I use a spray bottle for the mix. Shake it up and spray the area to be Clayed. Just make sure to keep the surface area lubricated while using the ClayBar.
3. I would definitely recommend you remove the wax buildup on your paint. Just use Liquid Dawn (hand dishwashing liquid) as a car wash. It has a high alkaline content which cuts right thru carnauba wax, paraffin, silicone oils, etc. This will get your paint finish squeeky clean and wax free.
I don't advise making a habit of washing your car with Dawn. But for this scenario it's fine. High alkaline products like Dawn are tough on polishes. It will never harm the paint finish though. A car wash is made specifically to clean without removing durable polishes. ALSO, Make sure you remove any water spots, before you apply my products. Because Zaino has no abrasives or harsh solvents it will not remove water spots or stains. Z-18 ClayBar is great for removing any paint surface contaminants. Re-wash the entire vehicle with Z-7 Car Wash immediately after the ClayBar
Cleaning Process.
4. The basic products you will need are Z1 or the new ZFX accelerator additive, Z2, Z5 (optional, but highly recommended), Z6 and Z7.
Note: The New ZFX accelerator additive is our latest innovation and designed as a substitute and/or replacement for Z-1.
5. Start with either Z-1 Polish Lok as per directions OR the preferred New ZFX accelerator additive. If you are using Z-1 it does not need to dry. Remember do not wipe off the Z-1 Polish Lok. Apply Z-5 or Z-2 directly over the Z-1. Z-5 is the Hot ticket for a swirl free, flawless paint finish. Usually one to three coats will accomplish that.
6. Let Z-5 or Z-2 polish dry at least one hour. Please NOTE: Zaino Show Car Polish works best at 60 degrees or higher. However, it can be applied down to temperatures of 45 degrees. It just will take much, much longer to dry. As much as two to three hours drying time is required if the temperature is 50 degrees or below. Also, If the humidity is high. Longer drying time is necessary. Humidity is a killer on the drying time of Z-2 or Z-5. The moisture in the air hinders drying time up to four times longer than normal. Sorry, but I can't help this. When you try to remove Z-2 or Z-5 when it is still wet. All you're accomplishing is moving it around. Kinda like reapplying it. Also you need to use a LARGE White 100% Bath size towel (please refer to my Tips & Tricks sheet on my web site for the proper towels to use) to remove Z-2 or Z-5. Smaller towels will not work efficiently.
To test if Z-2 or Z-5 is dry and ready to be removed. Wipe your finger on a hazed section. It should immediately come off and leave a crytal clear finish. If it smears, it is still wet. You can leave Z-2 or Z-5 on for hours or overnight if you desire. When it is not humid Z-2 will take anywhere from 30 to 60 minutes to dry. Depending on how heavy you applied it. I have applied Z-2 in the Arizona sun and it dried in approx. 3 to 5 minutes. I have also applied it in 38 degree temperature and it took about 2 to 3 hours to dry. Be patient. It's worth it. Different situations affect drying times. Also, remember you have Z-1 and Z-5 both on the car. That is two products that have to dry at one time. Takes longer. Z-2 or Z-5 does not cotain any oils and once it's dry will never ever look smeary or feel greasy. If you remove Z-2 or Z-5 before it is thoroughly dry and get any smears. Just wipe down the car with a damp cotton towel. This will remove any smears. Don't use Z-6 until you wipe the car down. If you'd like call me and I'll help you out with more info!
Note: If you are using the New ZFX accelerator additive drying time is greatly reduced.
7. After removal of Zaino Z-2 or Z-5. You should wait 24 hours if the outside temperature is under 70 degrees and 6 hours if over 70 degrees, before applying the next coat of Z-5 or Z-2.
8. Use Z-6 "Gloss Enhancer" spray as per directions, between each and every coat of Z-5 or Z-2. It really helps give a three dimensional look.
It's antistatic properties will reduce dust and dirt pickup by 60%. Z-6 can be used immediately after removing Z-2 or Z-5 or right before applying the next coat of Z-2 or Z-5. Most of my customers prefer to use Z-6 both, before and after Z-2 or Z-5 for that extra gloss boost.
9. You can switch to Z-2 as soon as you are happy with the way the paint finish looks. Example, no more swirls, scratches etc. It's up to you. Z-2 has higher optical properties than Z-5. You can go from Z-2 to Z-5 and then back to Z-2 as often as you want. Z-2 and Z-5 are 100% compatible and interchangeable. You should always end with Z-2 as the last coat because of its higher optics.
10. The number of coats of Z-2 or Z-5 is up to you. When you reach the level of enhancement you like, normal maintenence with Z-7 Car Wash and Z-6 "Gloss Enhancer" spray is all that's necessary. Naturally apply a coat of Z-2 or Z-5 whenever you feel it is required.
NOTE: One application of Zaino Z-2 or Z-5 will outlast anything in the industry and is all you'll ever need for an average vehicle. However, Multiple coats will achieve an even deeper, wetter-looking, ultra high gloss. Plus higher paint protection. It's up to you....You be the judge...
ALWAYS use only 100% Cotton towels. They must be Made in USA. Brand name (Cannon or Fieldcrest) large white bath size towels.
A BEAUTIFUL SHOW CAR FINISH IN A DAY!
Zaino Show Car Polish is designed to be layered. With each layer you apply, your car's paint looks better and feels smoother. Depth, gloss and clarity all increase with each coat.
Like all other polymer based polish and protection systems, Zaino Show Car Polish must cure before applying subsequent coats. The curing process allows the polymer chains to cross-link, building strength and durability. If the polymer strands have not cross-linked (cured), applying a fresh coat of polish will not achieve the optimum layered result. Consequently, creating a show car finish can be a long process of applying a layer, waiting, and applying another layer.
The Wait is Over!
Zaino Bros' ZFX™ Show Car Polish accelerator solves the wait problem. We worked for several years to engineer a molecular reaction that causes the polymers in Zaino Show Car Polish to set rapidly. Using ZFX™ with your choice of Z-2, Z-3 or Z-5 Show Car Polish, it is now possible to apply two or three coats of polish in a single day to create beautiful show car special effects. The result is nothing less than stunning.
ZFX™ saves you time and effort. It's no longer necessary to keep your car in the garage for a whole weekend just so you can apply two or three coats of polish. Using ZFX™, you'll apply multiple coats in just a few hours.
Prior to using ZFX™ Enabled Show Car Polish
Before applying ZFX™ enabled Show Car Polish, wash, dry and inspect your car’s finish. It should be very smooth. If the paint has a rough, bumpy feel, you have surface contamination which must be removed using our Z-18 ClayBar.
Prior to using Zaino Show Car Polish for the first time, we recommend using Dawn dishwashing liquid to wash your car. Dawn will dissolve wax and other sealants, and easily removes grease, tar and bug remains. Be sure to rinse your car very well after using Dawn. After your first application of Zaino Show Car Polish, use Z-7 Show Car Wash for regular washing.
Mixing ZFX™ with Show Car Polish
Each ZFX™ kit comes with a 2ml vial of accelerator mix and several 2 ounce mixing bottles. A single ZFX™ kit provides enough mix to accommodate 16 ounces of Zaino Show Car Polish.
Pour one to two ounces of Show Car Polish into a 2 ounce mixing bottle. For each ounce of polish, add 4 to 5 drops of ZFX™ (no more than 10 drops for two full ounces), screw the cap back on, and shake vigorously for 60 to 90 seconds.
While you get your towels and applicators ready, allow the ZFX™ enabled Zaino Show Car Polish to sit for five minutes so the ZFX™ can begin activating the polish. Give the applicator bottle a final shake for 10 seconds before using.
Applying ZFX™ Enabled Show Car Polish
Follow these easy steps:
Apply Zaino Show Car Polish enabled with ZFX™ with a 100%, made in the USA, cotton applicator. Use the polish sparingly. A small amount goes a long way, and you will be applying multiple coats.
Squirt a dime size dab of polish on your applicator and rub it into your paint using circular hand motions. Then, go over the same area using a straight back and forth motion on top panels and an up and down motion on side panels. Allow the polish to haze over (20 minutes is sufficient).
Buff off the Show Car Polish residue with a high quality, 100%, made in the USA, cotton detailing towel.
After buffing, spray the car with a light mist of Z-6 Ultra Clean™ detailing spray. Z-6 will help buff away any remaining residue and enhances the brightness of the finish. Using Z-6, the next coat of Zaino Show Car Polish will apply even easier.
You're now ready to apply your next coat of Zaino Show Car Polish enabled with ZFX™. There's no need to wait. Simply follow steps 1-4 above one more time. Use a fresh cotton buffing towel to remove each coat of ZFX™ enabled Show Car Polish.
Note: Apply no more than three coats of Zaino Show Car Polish enabled with ZFX™ in a 24 hour period. For optimum results, use your ZFX™ enabled polish within 6 hours of mixing. Use a fresh cotton buffing towel for removal of each coat.
Note: When you are finished polishing, wash the mixing bottle inside and out with a heavy concentration of liquid dishwashing detergent and thoroughly rinse. The ZFX™ mixing bottles cannot be reused if the polish remains in the bottle for more than 12 hours. After 12 hours, it is not possible to completely clean the mixing bottle. Throw the mixing bottle and any unused polish contents away after 12 hours.
Puntacanaviper
