P0432 @ 22,354 miles
Barry
Kill Devil Hills, NC USA
This code popped up with no other codes on my 2000 GTS. Efficiency for the catalytic converter on engine bank 2 is below efficiency, (passenger side?). When the car is driven it is driven, and not by a little old lady, so I'm wondering what is with this code and how to rid myself of it. Yes it keeps coming back so there is a real issue and I have taken it for a long drive at speed. Any suggestions would be greatly appreciated. P0432.
Could be an O2 sensor (I think rear given that code), but it's also entirely possible it's just exactly what it says, a bad catalyst. I had this show up on my wife's 09 Malibu and the ultimate remedy was replacing the catalyst for me.
steve e
On the more advanced diagnostic computers you can read what that rear O2 is doing and then you can make an accurate decision on what needs to be replaced the O2 or the Cat.
Twinturbosd
St. Louis, MO
You have 2 o2 sensors one b4 the cat and after the cat, bank 2 is after. It doesn’t effect anything except emissions, it is dang near plug and pay too, you can replace the sensor Yourself for cheap...you’d be surprised. This code and problem are the same meaning on all almost all cars.
No worries just irritating. Still drivable...
steve e
The O2 sensor is just like a spark plug with a wire and electrical plug at the end of the wire, if you can change a spark plug you can change an O2 sensor.
InTheZoneAC
Check rear O2 sensor and wiring making sure nothing is frayed
Also would be a good time to check your spark plugs on the same side of the questionable rear O2 sensor.
I doubt your cat is bad with low miles unless its somehow falling apart internally.
Does it mention at all if bank 2 sensor 2 is bad or just cat efficiency?
Barry
Barry
The exact readout is PO432 Main catalyst efficiency below threshold. The car only has 22,354 mils on it. I'm having a hard time believing anything went bad, but there is the code.
TexasViper35
Agree with you on the catalytic converter likely not being bad with only 22K miles.
Are you running some non standard gasoline (like super high octane race gas) or putting additives in your fuel?
