Passenger Air Bag Off Light Coming on intermittently
JasonSSG
United States
Just started to have this problem. It happens occasionally, my 09 is still under warranty so Ill have my local dealer look at it, but I was wondering if this is a known issue. I say this because I've had new tires installed (OEM tires) and the TPS light still stays on. I was just wondering if there was any known issues common with this. Thanks
J
JasonSSG
United States
The car only does it rarely from start up. After I turn the key on and all the dash lights do their check the airbag light stays on. If I turn the car off and turn it back on the light will then turn off as it should. Its done this a few times and I beleive it to be a faulty light/and/or sensor.
You might need to check connectors under the seats...have heard of similar situations with airbag lights on other Gen IV's.
For TPS, the C-J-D-R dealer will need to re-program your module using a DRB III.
