The new kit is designed very well and produces more power than the previous unit because of the new intake design. The balancer is pinned to the crank. Unless you plan on road racing the car, the stock rods and pistons should be fine. The most important thing on these cast piston engines is that you make sure you check the air fuel and timing calibrations on the dyno and make sure everything is working right once you have it installed.
