Bruce H.
Many may know that R-Compound tires like the Corsa that came with the optional Track Pack and TA cannot withstand freezing temps. A call to Pirelli this morning revealed that 5 degrees celius is the lowest temps that they recommend for the Corsa. That's for storage on or off the car, to drive the car, or even roll it on the tires. Much below that and they will crack...with high certaintly. I asked because I expect my TA to be transported from the factory possibly next month in below freezing temps, and while it will be put in a heated space afterwards, the damage could have already been done. Cracks will appear on the face of the tire if damaged, and they will appear right away, not months later. The P-Zeros don't have an official minimum temperature, but they don't recommend much below -5 to -10 celcius.
Everyone should check their own tires if they have seen freezing or near freezing temps. And if anyone is taking delivery of a Viper that may have sat in cold weather it would be worth a careful inch by inch examination of the tires, and have them replaced under warranty if damaged. Once the car leaves the dealer you could have a very hard time proving when they were damaged.
Bruce
Bruce
