Power door lock problem
red97vipergts
Here we go again , Just got the car straightened out with the every now and then not starting problem , after changing the clutch switch with no luck I read on here about cleaning all the terminals which worked . Finally was not worried about driving anywhere and getting stuck , then I get home last night after driving all day and leave the car in the driveway . Go out later to put it in the garage and the doors are locked and will not unlock even with the remote , never had any probs with the remote before , swapped batteries with my other remote no luck , tried holding both buttons down nothing again (no chirping at all) . Worst part was someone messed with the drivers door before I got the car and the manual latch doesn't work . I had to go through the pass door and put it in nuetral and just pushed it in the garage . Wondering if it could be a fuse or anything minor before I go into changing the EEM . I read about Taking the pos cable off . I was gonna try that tonight . Any ideas would be appreciated . If it is the EEM is there anyway to pinpoint it so I dont change it for no reason . Thanks in advance , for any advice .:dunno:
R
red97vipergts
Fixed , after work just disconnected the pos cable in the fuse box for 5 min , reconnected it and they started working again , found that in a post on here
