POWER STEERING RES. on my 94
SNKEBIT
western wisc.
Is it viper only or do they come off something else?
Thought I saw something about them being from a diff. DC product.
I think my resivor is leaking. Haven't got it off yet to find out for sure. The lines are NOT leaking, or the cap.
TIA :2tu:
IEATVETS
Cottage Grove, Wis.
The one that is on a Chrysler Sebring will probably fit but DC has to have the ever popular "viper tax" as we all know! By the way Mitch, didn't you mean TNA instead of TIA?
Bad_Byte
Corpus Christi Tx
The pump is off of a Jeep Cherokee or some such truck. From what I gather the reservoir is viper at least when I changed mine I had to use the same reservoir.
I'm betting its your pump seal that's leaking.
SNKEBIT
SNKEBIT
western wisc.
it is leaking below the high pressure fitting but it isn't coming from the fitting, dry there. Not coming from the front seal either. Literally drips out at a good pace. I suspect the reservior is cracked, how does that happen???? ***???? :mad:
Viper Wizard
South Salem, NY USA
Hey Mitchell,
The pump is from a heep, I mean Jeep :D
#83503495 Reservoir package, W/clips & O/rings MSRP $87.35
I keep them in stock if you need one. :cool:
RoyV101621
Indiana Suburbs of Chicago
My power steering pump was leaking after the motor was returned from Arrow. I replaced the METRIC O-ring (colored red) between the reservoir and the pump for the Hefty, Hefty, Hefty, price of $0.80. No more leak.
SNKEBIT
SNKEBIT
western wisc.
Thanks for all the info guys!!!!
Now, out to the garage to see exactly what crapped out.
:headbang: :headbang: :headbang: :headbang:
frankthedude
