power window retrofit to 96 rt/10
malcoll
Jacksonville Florida
So James Bell... did you ever complete your conversion??? Jay is your's complete??
I am back to considering this project.. as I really do love my 1996 RT... but I am now daily driving the Viper again and I am leaning towards the Gen 2............
I found doors for $1,000 each......
Jay Herbert
Sunnyvale, CA
Mr. Bells list is pretty spot on:
"exerpted"
You will need a set of complete doors from a 1997-2002 RT/10.
Remember the seat belt location is different. I use a Simpson 5 point harness through my seat, so I do not use the newer or older belts.
You will need the window/door seal (very expensive new-try to buy used). The newer windshield pillar has a short channel screwed to the side of it. You will need this to hold the window/door seal. The newer pillar has a grove to hide the channel, but it will still fit the old pillar.
I also bought the sport bar pad, since it is shorter. It fits between the doors instead of over the doors
You will need a newer style top. The mounts on the newer top are different, but it could be changed.
You will need to run a wire harness for the electric door latch and power windows. I am mounting the window switches in the door panels
The latches and hinges are the same.
A little more:
On top of the above, I put in a new windshield surround to hide the seals and fit the top(s) W/O any mods. I bought both a Gen II hardtop and a Gen II soft top, both fit right on, no issues what-so-ever. I should say Ed did.... do not try this at home. First, all the A/C ducting will not line up, Ed took the ducting off the old windshield and grafted it onto the new one. Then the dash will not fit, Ed spent hours cutomizing the dash to mate up with the windshield surround.
We have not put on the door panals yet, I'm betting they will not mate up with the dash and will need modding too, I get that job :) I told Ed I'd doo the door panels and the electrical.
The "hard" part of the conversion is done and all buttoned up. Unfortunately, the digital camera I sent Ed died, so I have no pictures of the car with the top and doors all fitted.
My advice, buy a '97 or later if you want roll up window doors... it's a lot easier to add side pipes to a Gen II RT/10 ;)
Jay Herbert
Sunnyvale, CA
Heck... just buy this Viper that just went into the classifieds.... take off the nitrous or just sell the hot-rodded engine and put in a new one if concerned about racing past:
1999 HIGHLY MODIFIED RT-10|1999 Silver Dodge Viper RT10~nl~42K miles. Extended warranty~nl~Tuning by PBJ~nl~PERFORMANCE~nl~Greg Good Cylinder Heads and Comp Cam upgrade.~nl~Extruded/honed intake manifold.~nl~Fluidyne Aluminum 3 core Radiator.~nl~70MM throttle bodies.~nl~T&D roller rockers.~nl~Smooth tubes. K&N filters.~nl~Custom airbox.~nl~March pulley set upgrade.~nl~Sealed power lifters upgrade.~nl~Belanger headers.~nl~Magnecor plug wires.~nl~180 degree thermostat.~nl~VEC 2.~nl~Hurst line-loc.~nl~Custom high performance fuel system.~nl~Corsa 3” catback exhaust.~nl~Eiboch springs.~nl~Energy suspension bushings.~nl~Eradispeed drilled/slotted rotors.~nl~Stainless steel brake lines.~nl~HID lights~nl~EBC brake pads.~nl~HRE 547 Wheels~nl~ViperMania custom hardtop~nl~Autoform re
ar deck spoiler~nl~LeMans style gas cap~nl~Color coordinated/vented windshield cowl~nl~Custom three gauge pod set-up (fuel pressure, nitrous pressure, a/f ratio)~nl~Custom carbon fiber interior upgrade (not that cheap 3M stuff)~nl~Team-tech six point harnesses~nl~MOMO steering wheel~nl~MGM interior accessories upgrades~nl~Seat lowering kit~nl~Custom audio/video system;~nl~-panasonic in dash cd/dvd player 7” fold out screen~nl~-JL audio 6.5 door components~nl~-JL audio 6W0 sub with custom enclosure~nl~-JL audio 300x4 amp and crossover~nl~-six disc changer~nl~RaceTested high power nitrous system~nl~-custom designed for viper~nl~-complete turnkey system including four 15lb bottles~nl~-nine second quarter mile capability~nl~~nl~As always, trades welcome, and we can deliver this car in our own enclosed trailer. Call 877-755-1751, ask for sales, or email with questions.|39995.00
Toby52
