sdaddy
I have seen several posts where someone said they prefilled the oil filter before installing it. What is supposed to be the point of this? I have always oiled the gasket and called it good. I asked someone who worked at an oil change shop and they said they generally prefill filters on diesels where the filter is a verticle mount, but not on anything else.
From the position of the oil filter fitting, I would think most oil in it would come back out during the install. Since the car seems to take not quite 10 quarts, this may be a way of disposing of the excess oil (on the garage floor) to get it to come exactly to the fill line. Any other good reason?
Also, the manual says there should be a pan plug seal (gasket), but when I have changed oil after my Viper Tech doing so previously, I have found they just put the plug in with no seal when they did it.
