eucharistos
are y'all talking canola or olive oil
I pre-fill whenever I can. At first start (also from winter storage), I crank the car a few times before holding the ignition to start the car. Just trying to have a little preventative measures.
Nick
Ive never filled a oil filter yet. Ive done hundreds of oil changes with no issue. I might just change my methods after reading this thread.
You want technical?Asp Man said:"wick" the oil up? could you get a little more technical with that?
Well, it's technically not dry after just an oil-change. And from the above link: Hydrodynamic bearings rely on bearing motion to **** fluid into the bearing and may have high friction and short life at speeds lower than design or during starts and stops.asp man said:You're saying running the engine essentialy dry for that first few seconds while the oil presure comes up, bearings loaded while it runs at several hundred rpm is better than cranking it over on the starter to get the oil pump and galleys primed?
hey, you do what you want. It's your engine.asp man said:Spurious thought at it's best. Never primed an engine before?
You want technical?Here... have at it: Hydrodynamic Bearings
hey, you do what you want. It's your engine.![]()
You do realize that at startup, it is a hydrodynamic behavior, right? The velocity at the oil-film "wedge" has everything to do with the crank getting up off the bearing and reducing wear. Much more likely at startup RPM than cranking RPM. The pump also does more work with RPM.Asp Man said:"...a large part of the bearing wear occurs during start up, and shut down.".
If you feel that way, fine. You've mangaged to convey both an arrogant and a condescending attitude toward me for no apparent reason.Asp Man said:You've managed to both embarrass yourself and support my previous statement.
Blue--might be "dummy move" today, but many moons ago it was done to "flush" engine sludge.. You must be a youngster.
Sdaddy, you must be an older fella to remember the kerosene "flush". My father told me to do that on my first car, a 1956 Belair 265 to clean it out. I guess there was no detergent oil back then.
On to prefilling the filter. Cleaner way is much easier. Open hood, remove fuse cover and remove the relay for the fuel pump. After replacing the filter and fill the oil, spin the engine over until gauge reads auabout 40-50 psi. Then double check oil level and awaaaaay ya go with no mess and no damage
Here's some more reading for anyone interested:Plain Bearings
I'm sorry if I gave the impression of dismissing the pump's importance. That wasn't my intention at all. The oil pump is indeed critical, but so is the rotation of the crank, especially in the first few seconds after cranking.Asp Man said:You still cannot seem to understand that what we're dealing with here is an engine that requires a pump to move the oil to the bearing/jounals...Cranking the engine turns the oil pump, that's all I'm saying. You dismiss this as doing nothing.
Well yes, but the velocity (rotational) of the journal is just as important to intended design as the pressure feeding it. I won't deny the importance of the oil getting in there as fast as possible, but it's equally critical to also get the crank spinning up quickly to "lift off" the bearing. Starting RPM will accomplish both of these faster than cranking RPM. Depending on clearances, you could have 100psi of oil pressure and a slow spinning crank could still drag along the bearing surface.Asp man said:You cannot get around the simple fact that the bearings and journals in your engine are designed that in order to support the journals off of the bearing surface oil must be provided with enough presure to do so. You can't have it both ways, my friend.
If it's just a misuse of the word "wick" that you're getting at, fine. Maybe it's not the best word to describe the way the oil film is drawn forward and pushed along by the crank just before the pump pressure becomes effective. There is a film of oil that remains after shut-down. Take an engine down and tell me there isn't. It's small, but it's there and it's important. This oil becomes what is essentially a hydraulic wedge, which increases as pressure comes up. Maybe "wicks" wasn't the appropriate word... okay, I'll confess to the shadetree technicality.Asp man said:This shadetree idea that that there oil wicks on up in there somehow, holds no merit and is vastly different that the hydrodynamic principle mentioned in that article and you've yet to explain how it (wicking of oil to the bearings) happens...or let it go.
