mjorgensen Woodhouse
Alright, I guess I owe an apology, after talking with Toddy, I can believe the numbers, congratulations to the both of you, guess I should not have been so skeptical.
Random note to record video of yourself at 200mph..
Thanks for posting, but curious how you are making the video.
My track extension must have gotten low enough to make contact with the road and it ground through 3 of the fasteners which then let the passeneger side fall down and crack my carbon fiber front mount. You have to understand the noise level with 3" exhaust & no cats and the ACR-X Borla Mufflers at those speeds is almost deafining so I never heard the track extension make contact until I was slowing down. Since I am going to use the "street" spoiler next time I have removed my hood vent mesh to allow more down force.Can you go into more detail as to why the extension shouldn't be used at that speed?
Do you think the Mopar PCM is a worth while upgrade? I'm doing very similar mods to my 09 VOI good luck and impressive results!
Holding a small HD Cam in my right hand while driving with my left hand. In the longer video you can easily tell when I had to shift from 4th to 5th because the video really gets jossled around. The video was not ment to document anything, I was just curious if I could even make a video while trying to drive one handed.
I already have a new GoPro 2 and it should be MUCH BETTER next time out...![]()
My kid just set up my full face helmet with a go pro stick on mount on the chin and one on the right jaw side. Worked perfect for seeing the tach/speedo at a half mile roll race we did a couple of weeks ago. For the speeds you're running, a helmet might not be a bad idea anyway.
Cheers,
George
Loving this build!
Well, I thoought I would post a few pictures of my intake ports so everyone can see how much oil the stock crankcase venting puts into your cylinders. Keep in mind my car has less than 500 miles on it........
In this last pic of the head you can actually see oil running out the intake ports!!
We went over the solution on page 3 towards the botttom of the page post #84. Problem solved.![]()
