Question about hood pads
Viper Wizard
South Salem, NY USA
Luis,
If the screw is behind the pad? It is held to the hood with T clips, to remove them you have to get behind them and pry them out [they may break!
]. More then likely the screw has gone into the hood itself! For-get-about-it! Get a new screw!
Do a search here, this has been discussed before.
Viper Wizard
South Salem, NY USA
OH, the other part of your question:
There is no right Hood Pad only the left.
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Viper Wizard on 07-23-2002 at 07:23 PM</font>
ruckdr
Renton, WA USA
3DViper,
The RIGHT hood pad DOES exist. I have both on my car (1996 RT/10). Contact Dodge, for your year and model.
Later,
JonB
Legacy\Supporting Vendor
Columbia River Gorge
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by 3DViper:
I also noticed that the side hood pad on the passenger's side is missing, do you guys know if I can buy that? thank you
luis Batista
<HR></BLOCKQUOTE>
Luis, YES, you can buy that pad. The year matters. Mr Ruckman has an insulation pad on the right because he has a GEN ONE.
The PCM/ECU is on the right, and insulated. I assume you have a G-2? ECU is on le left, and no insulation is needed/installed on the right. But you can buy the part. Tator's, PartsRack, etc. About $30 Thanks
sham5430
