question for guys with high hp and tourqe numbers
speedshftr
wilmington delaware
for you guys that are making 700 plus pounds of touqe at the rear wheels/how is the car driving?will they just break loose at part throttle?even in the upper gears?im considering a blown gts and im just wondering how streetable is 650rwhp car?thank you for those who take the time to reply
thanks
richard
Casey
Valparaiso, IN.
You need to take a ride in a Blown Viper and all your questions will be answered immediately! :laugh:
Sticky tires help with the 1st/2nd gear traction. You learn quickly how to control your right FOOT!
Steetable? My Heffner SC'd GTS couldn't be any better for the street! :2tu:
GaryA
USA
My car is definitely very streetable with over 800 rwhp. I can break the tires loose pretty much at will, but it is still very driveable.
If you hit the pedal hard it will break the tires loose (not just in 1st and 2nd). Learning how to "pedal" the accelerator to keep it at the point of maintaining traction while at the same time maximizing power put down to the road is the key to getting the most out of the power.
I think 650 rwhp is a great street power level. Of course, like anything else, you get used to it and then you want more.
2000 Black RT/10
Heffner 1000SCi 843 rwhp 792 rwtq 10.20 ET @ 141 MPH
Heffner Performance - Home of the World's First 9-second supercharged Viper!
pullshard
Well, I'm new to vipers and driving this 680 beast is a challenge. Dump clutch just a tad to fast and your spinning rubber. Come around a corner and jump on it to fast and here comes the rear-end. But it feels pretty controllable once you get use to it. I would say that driving these cars is an experience like no other. Can you say "feather the gas".
96 GTS
Indiana
If you stab the throttle in 1st, 2nd, or 3rd, expect to burn up your tires. I've found that a progressive "rolling on" of the throttle helps to control wheel spin. Like Gary said, you will learn to get into the throttle just below the point of losing traction. Many other factors come into play also, such as ambient temperature, road surface, tires, etc. One last piece of advice, never nail the throttle unless your front wheels are straight. Good luck. :2tu:
oldvenom
