Question on Re powdercoating Valve covers
VIPER BAZ UK
ENGLAND
Getting my valve covers Re-powdercoated,Will they be OK in an oven at 200 degrees C??????????
Baz :2tu:
GT40DOC
ARIZONA
I have done a number of valve covers(not viper) and had absolutely no problems. The powderpainters proably won't take the temp to 200 C. Should do fine. Let us know how they turn out.
Doc
PhoenixGTS
Phoenix Arizona
200C is going to be trouble. My powder coater runs there oven at 400F so right above 200C on the initial bake. 200C would be pushing it and man does powder stink when you over heat it.
V
VIPER BAZ UK
ENGLAND
Optimum temperature for curing powder is actually bringing the part to 385 degrees which normally takes 15-25 minutes. We do them all the time!
And the valve covers will be OK at this temp?????
Baz :2tu:
Joel
Ireland
Yellow ? What about the intake ? Baz, while youre there, could you ask the company about wrinkle finish black.....similar to the finish on a 360 Modena.
BACKNBLACK
NY
Baz no problem at all. I powder coated my heat shields on my bike.They are way over 200 and still look great
V
VIPER BAZ UK
ENGLAND
Just been up to the powder coaters,They are worried about the sealer in the valve covers (inside at the top)also sand blasting as well..
Intake is fine just alot of masking to be done..
Baz :2tu:
BACKNBLACK
NY
Baz let them cover it.If you have any problems I have a guy who specialized only in powder coating in NY. Very good prices adn incredible work.
V
VIPER BAZ UK
ENGLAND
Cheers Tony The shipping might be more than the work itself..
Companys over here dont seem to want this sort of work...
Managed to get some washers that are a nice tight fit in the injector ports..
And i'm going to get some plexiglass for the throttle body inlets and put the bolts through..
Baz :2tu:
Neil - UK
ENGLAND
Baz
let me know what plexiglass you need, I've tons of stuff sitting here and I'll get it machined to shape
