The real estate market is doing me so well, that I am considering adding a supercharger in celebration.
I have found alot of info on blown vs. tt, etc.
what i am wondering though, is at what point do you do more than add the supercharger or TT?
In other words, when do you upgrade the brakes, and to what? at what point are the upgraded half-shafts needed? when is the fuel system upgraded? what else am i not thinking of that pertains to this question?
thanks in advance
Big-n-italian, exactly what kind of driving will you be doing? Street only? Roadcourse? Street tires, slicks and skinnies?
If you do not care about brake dust, I can sell you some ferodo(don't remember the exact model # off hand) front pads and some performance friction rear pads.
The aggressive pads with some braided stainless brake lines will achieve a noticeable improvement in your car's braking performance.
In addition to the Unitrax titanium supershafts, I would also recommend picking up a pair of Unitrax 1/2 shaft loops.
I got home at 2:30 am from reinstalling a differential and heavy duty Unitrax 1/2 shafts(with all newly replaced U-joints and u-joint strap kits) The last installer used the old strap kits and no loc-tite.
Old strap kits and no Loc-tite lead to the U-joint caps coming off and destroying the axle stubs coming out of the diff. It all had to be replaced redone.
We used new strap kits, Loc-tite and also installed the 1/2 shaft loops for good measure.
I can get you all the parts you need and do the installation if you would like.
My cell # is 630-878-3907.
As far as the whole supercharger vs turbocharger debate is concerned, I can hook you up with a cutting edge, intercooled, front mounted twin turbo system where we can start you out at around 600 RWHP and you could eventually make in excess of 1400-1500 HP with the appropriate engine, fuel system and engine management upgrades. There is no other system out there that can do this.
After recently installing one, I have to say the Roe blowers look like a million bucks. You open the hood and WHAM! It looks awesome!
Our DIY twin turbo will have a similar visual impact to the Roe blower when you open the hood.
So there is upgradeability, functionality and bling
If you have any other questions, please feel free to give me a call anytime.
Good luck in your pursuit of safe power AND stopping power! Congrats on your real estate success!
