Questions on racing tires
Venom 1000TT
AZ USA
I just bought Hoosier's for my 18" BBS wheels. They are the DOT racing tires. My question is what tire pressure should I run them on? I plan on doing road courses..Poconos,Nazareth,etc.
I know with drag racing it depends on the traction you're getting to help determine pressure but I'm not sure on road racing. Also, what about tire temperature? Should I get a infrared temp meter? If so what kind? And what temperature should the tires be kept at or monitored? Any advice would be appreciated.
DanElam
Richmond, VA
Depends on the tire. On some tires we run the manufacturers spec. Other ones we run pressures a lot lower than what the manufacturer says.
Tire rack has some good information to get you started:
http://www.tirerack.com/tires/tiretech/competition/racepres.htm
One problem with Viper tires is that they are huge and tend to be a little thick. Differences in the manufacturing process mean that the tires aren't even in terms of consistency.
One of the best things you can buy if you are are serious about this is a pyrometer with a small probe (about $125). Don't get one of those laser/infrared pyrometers - they just get the surface temp and you need to know the real tire temperature. You are looking for consistency across the tire. Measure the inside, middle, and outside of the tire. If the tire is hotter in the middle, that means that you have too much air pressure. If the middle is lower, that means too little.
Most tires don't end up with consistency across them. Usually you have to take a look at the direction of heat differences. Keep in mind that there is no one 'right' temperature. We maintain spreadsheets of temperatures according to air temp, driver, and track. My Dad, for example, likes to slide the car (old Sunbeam Tiger driver) and he puts about 10F more in the rears than I do. We typically lower the back right about a half pound when he runs.
Finally, keep in mind that the air you put in the tires also matters. Try to keep dry air in the tires. Moisture in the air means that the water heats up inside the tire and makes pressures go crazy. That is why airplanes often use nitrogen (inert gas). Some race cars use it too, but it's too much of pain for most of us.
Have fun!
Andrew2KRT10
New York, where else?
I got Hoosiers that I ran at Watkins last year. Archer suggested that I start at 25 lbs. and then recheck after my session. He was right to tell me to recheck, because after my session I was up to 35 all around and had to adjust the pressure. SO, you can't just set the air and go for the day. You have to check frequently.
Andrew
Steve Ferguson
Burr Ridge, IL
I start at 19lbs in the rear and 21lbs in the front. After 3-4 laps I am usually around 36-39 lbs. This combo seems to work best for my style of driving.
Try some different pressures and see what works best for you. obviously there are way too many factors to give you the precise information you are looking for. The track temp, sunny or cloudy, modifications to your car, the way you like your Viper to preform, and your driving ability are all factors you will need in determining what pressures are best for you.
Good luck, and be safe!
Venom 1000TT
AZ USA
Thanks for the replies. I saw one of those pyrometers in Jegs for $107.99. Maybe I'll get one of those & experiment a little.
I also assume you torque the wheels(lug nuts) the same as stock at 90 ft/lbs. Correct?
pdmracing
Atlanta Ga
I have been running Hoosiers since 1996 with great sucess. Check out the Hoosier web sight for exact details ,they reccomend 42 to 44 psi HOT, AFTER a session. Your starting temp will depend on a number of factors, ambient temp, your driving ability, track condition ect. A fast driver can start at a lower pressure & quickly heat the tire to the desired temp/pressure where as a more inexperianced driver who is not pushing the car/tire as hard can start a little higher. I have found that in the long run , the Hoosier gives great wear & performance at the recommended HOT pressures.
sham5430
