Racing Fuel!
MbnViper
Hi guys,im wondering! going from 100 Octane Unleaded to 110 Octane also unleaded (Sunoco) adds any power? or better i dont bother, Mods listed below. thanks in advance .Mbn :laugh:
jp
Umea, Sweden.
In General---
As long as you have not icreased the compression is there no use of racing fule if you don do a significant igition advance.
Ron
Indianapolis
I would think that since you have the VEC2 and a supercharger (hence higher compression) you can program a more aggressive ignition curve (I assume) with the higher octane that might add some power.
I'd speak with Sean for more details....
Vreracing
Amarillo,Texas,USA
I agree that if the program for the Supercharger is programmed for the higher octane it would help.
I guess you could always put it in and see if it feels any different.
In the Porsche 993TT the factory computer will attempt to determine what the octane of the gas is and adjust the program accordingly. The effect you might say is "digital". You either have the advanced program or you don't. In a case such as that, the fuel makes a big difference. The effect does not feel linear you either have it or you don't.
1TONY1
Dalton Ga. (Chatt. Tn.)
You'll burn out your O2 sensers using leaded fuel, don't use 110 :crazy: :crazy: :crazy: :usa:
He said the 110 is unleaded. With 110 you should be able to run a 0 degree card (pulling no timing out) and if you have the updated vec2 you could even start advancing the timing. timing = power.
Gerald
Near Tampa Bay
Are you sure the 110 is unleaded???
Gerald
Atom
