Radiators......
Vip-RT10
Clearwater,FL.USA
I have a 93 RT/10 and I'm looking for people that have had their stock radiators replaced with after-market ones for better cooling. I'm thinking of getting a bigger radiator, so I would like to know who has done it and what they did, was it a problem? Info needed please....
treynor
Redwood City, CA
A while ago I replaced my '01's stock radiator with a much larger Fluidyne race radiator. It worked great -- temps stayed below 225 even in 100-degree heat on the racetrack. Unfortunately, it doesn't fit with the giant blower Doug's stuffing into the front of my car, so I'm switching back to the stock rad. I'd say if you have cooling issues which aren't related to thermostat or water pump, a larger radiator is an excellent mod.
PS: my fluidyne's for sale
Vip-RT10
Clearwater,FL.USA
OK, so it's your "old" radiator that I spoke to Doug about...OK. I just want to know if anyone has done this to a 93 rt that has the 2 fans shroud. I don't want to dismantle everything to put in a radiator. Doug was extremely nice as he always is in giving me info for the radiator.
treynor
Redwood City, CA
They address two separate issues. Sean's fan kit will keep your fan on after you turn off the car, reducing heat soak while parked. A larger radiator will help the car run cooler while it's running.
Vip-RT10
Clearwater,FL.USA
I was suggested to place a Sean Roe Fan relay system. Will this be a good idea instead of a custom radiator job?
sham5430
