Rear Fascia bolts question?
pocketAA
Allentown, PA
Guys,
I have noticed that the bolts under my rear fascia are all rusty looking. I remembered seeing a post on here in regards to changing them out for stainless steel bolts. I went to Lowe's and Ace hardware looking for something similar to replace the bolts with and could not find anything quite like the OEM versions. For those that have replaced the bolts, could you tell me where you got them from and maybe an image of one of the bolts so I can see what exactly you used? I found bolts that were similar, but they did not have that tappered tip at the end like the OEM ones do.
Thanks,
Brian
ViperJoe
Virginia
Road salt.
Mine are still black, but winter cleaning requires removing (to better wax the aea) and spraying with WD-40.
I'd just get some originals from DC
Matt M PA
Langhorne, PA USA
pocketAA....the tapered should not matter. As long as the thread is correct. I would also watch for the size of the washer as the original hardware will have dented the plastic panel where the washer pressed.
I pulled mine, blasted them, and re-shot with flat black. They originals are phosphated, and they do not hold up.
RandyS
Clovis, CA
Get them through DC. You might want to get the nuts also. Some people think they need a breaker bar to tighten everything. Four of mine were stripped on the left side.
Randy
P
pocketAA
Allentown, PA
yeah those are them, on the right of the above image. If I order them through DC, my guess is they are just going to oxide again like the old ones did. The guy who owned the car before me was very meticulous with the car. I doubt the car has seen rain or even any kind of salt from winter months. What if I paint them, will that prevent them from rusting?
Thanks.
KepRght
CA (925)
look in your phone book for "powder coating". have them shot in your body color. they should last forever
Joel
Ireland
You should be able to get dome head allen screws and large diameter washers in stainless. They are unc thread. Think they might be used on some applications of Harley
I got mine in the UK several years ago
sham5430
