Hi guys, hoping for some help. I recently completed rebuilding my 08 which was a insurance rebuild. Replaced the fender, rocker and quarter on the passenger side as well as front upper a arm and hub, rear hub, a arm and half shaft (used). The problem i have is on tight turns in either direction there is a grinding, growling, rubbing noise from the rear. At first i thought wheel bearing but it doesnt seem to make any noise in a straight line. I changed the diff fluid and used friction modifier, no change. Took the passenger side rear liner out to make sure it wasnt rubbing, still no change. Wondering if the used half shaft i put in had issues or if its diff related. Any insight you guys can offer would be appreciated. Car is lowered with kw btw. Thanks
