When talking about injector flow, you have to be sure and mention the operating pressure.
The standard injectors we supply in the kit have blue tops. They flowed 40 lb/hr at 55 psi. The lime green top injectors flowed 50 lb/hr at 55 psi. From memory, I think the graph showed the green tops at 44.5 lbs/hr at 43.5 psi.
Regards,
Sean
PS,
Joe, did you finish and drive the car with the bigger injectors and 8 psi pulley?
