vipergts1960
I received and had my Rotary lift installed today. So far, I have chosen not to bolt it down. I am not sure that was the best decision so I will probably end up bolting it down. I put my Viper on it for the first time tonight and a scary thing happened. I raised the car all the way up. The next thing you are suppose to do is lower it onto a lock. When I tried to do this, the runway at the left rear column did not lower causing the whole thing to start to twist with my car on it. I stopped immediately when I noticed this, raised it back up until it was even, then lowered it all the way down to the ground according to the instructions. The lowering to the ground when as I would have expected. Has anyone had a similar experience? The installer is coming back tomorrow to check it out. I have lost come confidence at this point.
