Hey Tom,
What provider said^^^^^^^^^^, its all club/organizer dependent.
When you are running?
I've run a couple events with Trackquest, and I think they are a good outfit for first timers. The instruction is of a reasonable quality, but in comparison to other open track clubs, the are a bit on the more expensive side. That said, you will get a ton more Viper specific instruction at Viperdays, ex: Buttonwillow ~Sept 7. These guys are awesome.
In terms of the excersize you describe, you can learn a bunch yourself in a big empty parking lot. Get the car going in a big circle maybe 70-100' diameter. Slowly add throttle and bring the speed up, not moving the input on the wheel, until the tires start squeeling and you experience a little push or scrubbing in the front end. Lift off the throttle and watch the car dive to the inside. It's pretty cool when you experience this the first time. It's about weight transfer, the abrupt lift unloads the weight from the rear and deposits it on the front end so the tires bite and you turn way more agressively even though you haven't moved the wheel. The deal you describe is to push the envelope, but I think that suddenly lift and spin thing only happens in Porsches (the favorite car of Todd Serota, the Traquest organizer) where the as*-end has all the weight.
You can figure out how to 'catch' the car too if you've ever driven a go-kart or on ice -- it's called steer into the slide.
