We had a long weekend up here in the North, so I finally got around to installing my S2000 start button I followed the instructions posted here in the past, with a few minor changes. I do have the updated interior with the mirror toggle switch. Since I put the start button in that location, I relocated the toggle switch father down, which actually looks quite good. Looks stock, imo.
Here are the parts that I used:
One S2000 start button. I looked around quite a bit for various options, but in the end, the S2000 button was the only one that looked good and well built. Most other buttons were cheaper ebay ones that just looked cheap.
One internal hard drive connector to hook up to the rear of the start button.
For the relay, I went for a combination of relay and connector, for two reasons. One, it was much easier to pre-wire before the install. Two, should the relay ever fail, I can just unplug it and replace it with another one in literally a few seconds.
I wired the relay into the driver side fuse box, so that it will be easily accessible, without having to take the dash apart to get to it.
Here's the final product Havn't had time for better pics, but you get the idea. Really happy with the result Viper can now only be started with the start button, not with the key, similar to the Gen3 setup. I found the best wire for the ign ON voltage is the black/orange one under the steering wheel. That way you can deal with all wires (red, yellow and bk/org) in one location.
