seat lowering assembly by northwind
Melanzana
mike at northwind is highly recommended. his seat lower kit works great and his service is wonderful!
KERS-VPR
I also purchased his kit and modified it to pick up 2 more notches rearward, about 3/4". Now I can't even get my fingers down behind the seat.
KERS-VPR
Make sure the bolt is on top and nut below so that the aluminum track will slide over it. At this point you will see the seat track pin will hit the aluminum rail but still having more notches for the seat to go back. I filed about 3/4" more off the aluminum rail that comes with the kit to allow for the seat to go back 2 more notches. If you buy or have the kit on your seat and turn it upside down, you should see what I'm talking about.
Andrew/USPWR
W. Palm Beach
Bought mine from Partrack.com. Not sure if it's Northwind. Will be the first mod to an SRT/10, if I ever find one.
One thing I will do first is paint the base semi-black to blend better with the carpet.
Jay Herbert
Sunnyvale, CA
Same part, PartsRack sells Northwind items like they do other items.
R
roofum
west burbs of chicago
how did you pick up two more notches.i have not taken the seat out yet to see .give me the run down .any info is very much appericiated
thanks kevin
KERS-VPR
the notches are already in the seat track, however on mine the aluminum track from Northwind restricted the seat from moving back into 2 of the existing notches. I filed about 3/4" of the aluminum Northwind track. The aluminum track from Northwind is already milled out, I just made their notch a little longer.
R
roofum
tanks i ordered it today if i have any problems i will post.i need a pillow to kneel on bum knee.saving up for a new one butt spend the money on the viper
