second hand parts value
PHILIP
Dunedin, NZ
I am Looking into the conversion of my 94 Rt/10 to right hand drive, I have found that I am able to buy the following parts manufactured for RHD:
dash fascia including glove box lid and insert
centre bezel
centre console
Left and right knee pad
plenum inlet
complete vent duct set (5 pieces)
left and right toe box assemblies consisting of several individual pieces each.
right toe box heat shield
A/c hose dryer to evap
A/C hose compressor to evap
steering gear mount
external convex mirror (left door)
handbrake tunnel section with ash tray recess
left splash shield insert
right splash shield insert
clutch and brake pedals
brake line set
heater hoses
hood plenum intake tube
hood plenum block off plate
side markers
left and right carpet set
remote oil filter adapter kit with oil lines and mount
power steering hoses
new steering rack with factory ratio’s and lock to lock.
Can someone give me an idea of what the parts that I remove from my car in order to install the new parts are likely to be worth? (the car has only 700 miles, so while they will be second hand they are virtually new.)
I am keen to know whether there is much value in them second hand, as if they are worth only a little it may be worth attempting to change some of them to suit.
Regards Philip
BADVENOM
port washington, n.y. usa
laws of supply and demand rule however from experience in talking to viper part dealer on second hand parts like partsrack and others around 50-60% sounds right depending on condition..
