Shifter question
wikkid
Under hard shifts my shifter moves all over the place. Car has 53K miles and is modded. Do i need new trans mounts to fix this? and how hard is the install? or motor mounts? im pretty used to it but it would be so much smoother if i could fix this. And a general price please?
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
New Woodhouse Poly Engine mounts will fix this and you won't believe the difference. I do have to warn you that changing out the motor mounts is a royal PIA though.
Omaha NE.
Although our mounts will make this much better the MGW shifter will also help prevent you from missing any shifts because of its more positive centering and feel.
ViperGear
