I want to do 19s, but will use 26.8" tall tires in the rear and the 275-35-19 Front tires which are 26.6" tall, instead of the 275/30, or 285/30-19 which are 1" shorter(25.6/25.8).
Basically the same overall diameter of the 20F/20R Nitto Invo set up most run on 20s but on 19s, which have more side wall.
Simialr to Bushido's Blue and White.
I want to know if any of you out there have that set up with Eibacks and lowering caps with no rubbing issues between the wheel fenders and the top of the tires, front and rear.
Front bottom clearance at the nose corners will be similar to a stock 18" set up on just Eibacks, so I'm not worried about that.
thanks!
if you can post some pics, great!!
thanks!
