All Blue ACR
I replaced my stock cats with RT cats and later added a 3" Belanger catback and headers. The RT cats made a huge difference in side-sill heat reduction. The RT cats are running 200 degrees cooler than the stock cats. Also, the aluminzed steel in the Belanger system seems to cool off quicker tham the stock pipes or the stainless steel catback I had prior to the Belanger setup. I then added my own version of vents to the front of the sills to allow air to circulate through the sills and push heat out through the back of the sills. No insulation was added. Amazing how much room is gained in the sills by removing the stock cats. Air now has a way to circulate through. My sills are much, much cooler to the touch. Hi-flow cats and side sill vents are worth the investment and seem to do the job. The principle is simple...get air moving through the sills so that the heat has somewhere to go other than inside the cabin or roasting side sills.
Can you share your vent setup please. This task will be first on my list when my car arrives
