Side sill screw question.
RikRok
Rather than getting than popping in threaded inserts, is there any reason the slide on body clips would work to fix stripped screws? I don't have the sill off yet, but I assume there is clearance for them.
You can also try a slightly larger screw of same length (stainless steel may appeal)...several have picked this approach and it has worked for a couple of years...so far.
Ron
Indianapolis
Knowing how the sills attach, I see no reason why they wouldn't work. Might be a corrosion issue as they tend to dig in when installed.
If you confirm, please post source and size.
No members online now.
kc651
