jknappster
I got the green light from the misses to get a single post lift. Is anyone currently using one? What brand is the best?
Why? Why a single post lift? There are advantages with either a two post or a four post, but why a single post?
Treesnake
It's leaves more room, or "leafs" more room?
If primarily for storage, then a single post makes sense....but can you actually work on a car on a single post lift?
You are correct!....
They are great for detailing, changing oil and.......
They are storage lifts.
They're Go-Jacks. Just look around for the best price. For the Viper, the 4500 or the 6200 models are the only ones I know that would work becuase of the width of the tires. The models also represent TOTAL weight that can be put on all 4. I like the 4500 better with dual rollers and they are usually a little cheaper as well.
What did you do to verify that the floor could take the load of a single post? Did you have to drill the cement to check thickness or did you know that already? Isn't there a minimum tensile strength that is required of the cement for a single post lift?
Looks awesome by the way. Nice garage but clearly you have room for more Vipers, Gen 5 in your future?
http://javascript<strong></strong>:;
those purple rollers at the bottom of the coupe.. what are they called and where can i get them? i been looking around for a little while and I must be searching the wrong names of it.
Awsome pic.... High res available?????
Just about to buy my lift... Flush mount scissor lift..
+1 on the High res availablity
That is one nice garage/shop and one sick car collection you have.
Treesnake - would you purchase the Bendpak brand again? Are there clearance issues/concerns?
